The AirGradient DIY Air Quality Sensor (Pro Presoldered-Version, PCB Version < 3.7)
These build instructions cover the pre-soldered version of the AirGradient Pro monitor kit for PCB version 3.6 and lower. If you have a different version please find your correct build instructions in this overview. The version number is printed on the PCB.
SkillDescription
ComputerA Linux, Mac, or Windows computer with the Arduino IDE installed to flash the software onto the D1 Mini. You can also flash the software directly from the browser.
ScrewdriversYou need Philips and hex (M6) Screwdrivers to close the enclosure.
ComponentApprox. Price
AirGradient Pro PCBwith OLED Display, connectors and pin sockets
D1 Mini v4 USB-Cwith pre-soldered pins
Plantower PMS5003 PM Sensorwith cable
Senseair S8 CO2 Sensorwith pre-soldered pins
SHT31 Temperature and Humidity Sensor Modulewith pre-soldered pins
USB-C Cable90-degree head
EnclosureUV-resistant injection molded ASA plastic
ScrewsThe longest screws are for the enclosure. The screws with the washer head are for the PCB and the remaining screws for the PMS sensor.
The schematics
Assembly
The assembly of the pre-soldered parts is very simple, just make sure you mount the components in the correct direction. The labels on the components should match the labels on the PCB.
D1 Mini
Put the D1 microcontroller onto the pin sockets labelled “Microcontroller”. Make sure that the orientation is correct and all pins slide into the sockets.
D1 Mini Placement
SHT31 Module (Temperature and Humidity)
Put the SHT31 Module onto the pin sockets labelled “SHT”. Make sure that the orientation is correct and all pins slide into the sockets.
SHT31 Module
Put the CO2 Module onto the pin sockets labelled “CO2 Sensor”. Make sure that the orientation is correct and all pins slide into the sockets.
SHT Module
PMS5003 (PMS Sensor)
The PMS Sensor is connected with the enclosed cable to the PCBs JST connector.
PMS Location
PMS JST Connector
Now you can power on the device and you should be able to see the display lighting up. If you flashed the Wi-Fi version, you need to connect it to the Wi-Fi. To do this open you Wi-Fi settings on the phone and look for a hot spot called “AirGradient______”. Then connect to it and enter your Wi-Fi network credentials. It will then connect to Wi-Fi and start displaying and sending the air quality data.
The pre-soldered version of the kit comes with the microcontroller D1 already flashed so that you can immediately use it. However, you might want to flash it again or change the code (e.g. to connect it to a different server). Also, the pre-soldered kit comes flashed by default with Celcius for the temperature unit and if you would like to use Fahrenheit you would need to reflash with below.
Note that you cannot flash through the USB-C port on the PCB as this one is only for power. For flashing always use the USB port on the D1 Mini itself.
For Standard PRO Presoldered Kit
With temperature in Celcius and Display top-left Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
With temperature in Fahrenheit and Display top-left Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
With Code for Optional SGP4x AirGradient TVOC Module
Manual Flashing with the Arduino Software
StepDescription
2Once it is installed, go to File, Example, AirGradient and select the PM OLED code
The AirGradient DIY sensor’s hardware and software is open source and licensed under the MIT license. So feel free to use it any way you like. We would be happy to hear from you and also appreciate any link back to our page.
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the “Software”), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
